The Dynasty 280 is not having any argon flow. I checked the regulator and it is having a positive gas flow. When the petal is pressed down the regulator will initially show that the gas is flowing but it immediatly drops off to almost zero. The regulator has two outputs so I connected the welder to the other output but I had the same issue. I looked at the hose and didn’t see any cuts where gas could be leaking.
As for me I just came in to get some weld time in so I am in no rush for anyone to look at this. Since I am here I’ll unplug the machine and put an out-of-order sign on it.
