Next time im at the space I’ll set them aside I’ll also put the call out for someone to do it via Facebook and see if I can get a quick volunteer.
Okely dokely. Really rough cutting ones are preferred just for piece of mind that I can’t really screw them up more,. I’ll work on whatever is easiest for yall to find though
- Return all pens/pencils/etc to the appropriate drawers
- Run the vacuum over the floors
- Check and make sure that the iron and/or heat press haven’t been left on without someone attending them. Fold up and put the ironing table away if nobody’s using it.
- Put all vinyl accessories (weeding equipment, exacto blades, etc.) back in the appropriate containers on the Vinyl cutting table.
- Put any vinyl scraps with area greater then 2 square inches with the Silhouette Cameo.
- Take out the trash
- Straighten chairs/stools
(sarcastic comment of the day) Would it be too much to add “you will likely be stabbed by these scissors if caught being used on anything other than fabric”? I think the really long label would be eye catching and the message would make someone maybe think twice.
