Test equipment abuse... or
Or… How I fixed a power supply… That someone abused.
One of the E-Lab’s BK Precision 1550 power supplies from Mouser was killed when a user hooked up some source of voltage to it backwards. The most likely culprit was a battery pack someone was trying to charge. The results were it showing 0.00 volts at 3.05 amps output when the output of the supply was turned on.
I took it apart and found 2 blown traces and a shorted protection diode mounted to the small PCB soldered directly to the output terminals. I patched across two blown traces and replaced the protection diode across the outputs of the supply. and the outputs now work and the short circuit is gone:
A tip of the hat to @artg_dms for helping to dig through the bins of parts to find a suitable diode to replace the shorted one and a donor diode whose legs were used to patch the traces.
Thanks for fixing this!
Raymond at work.
Everybody Loves Raymond.
How long did you wait to be able to say that?
Not long enough…
