Tear down table project possibility
I’ll beg for help from Tim, Zach, Mathew and or others willing to do some welding & fab
I have a heavy duty steel table and legs ( came from a US Army arms vault ) that may make for a good engine/transmission, differential, transfer case tear down table.
A lip /edge would need to be added(welded) to retain any fluids and a hole to drain / catch them in.
A table such as this could reduce the amount of after project clean up (did I say clean up?) and reduce wear and tear on the wood top shop tables
I like the idea, I think we probably put a nipple & ball valve to help with clean up of the fluids.
Tim,
A nipple is a great idea!
Maybe add some heavy duty castors?
See you there around 7pm
I like the idea of a skookum steel table for automotive work. Save the regular shop tables.
Anyone else giggling about nipples and balls? No just me?
Take it in context man. Nipple and ball fluids
I’ll also be there. Sounds like a fun project.
Teaching a class tomorrow evening but will swing by if possible.
