Desperately in need of help with design of single-stage model rocket that must come down in 2 separate parts(capsule w/ eggs inside & engine section). Don’t have any model rocket experience. Help me DMS, you’re my only hope
some experience some decades ago…
launch may be more trouble than landing
I am going to ignore my gut instinct to just declare that you have missed your launch window and ask some questions instead.
Have you already bought the motors you will be using? It is probably too late to order some and the stock at local hobby shops is rather unpredictable.
Do you already have the parts for the rocket? Again, it is likely too late to order them.
Have you assembled your team? TARC is short for Team America Rocketry Challenge. The task is intentionally difficult so that a single individual is unlikely to qualify.
Do you already have rocket performance simulation software like OpenRocket or RockSim and do you know how to use it? It is almost impossible to hit the performance criteria without simulating your design first.
Have you contacted the Dallas Area Rocket Society? It is a large and active club. Someone is likely to be able to give or sell you the needed motors and parts. But we cannot teach the needed rocket science within the just over a week to the deadline.
In a nutshell, the task this year is
I have a team of 3 people, we have all the parts we should need except an altimeter(I think) and are utilizing a vague idea of a design based on one we came across while scouring the internet. I’d love to be able to simulate it but with 10 days to finish building and launch I believe I’ve deprived myself that luxury.
Wow you can hit a target altitude accurate to one foot?? This is a lot different than the model rockets I used to launch…
You try to get as close as possible to that mark. I imagine very few teams hit it spot-on
The better teams can come pretty close.
We mentored a team from Rockwall-Heath which made numerous test flights and recorded the weather conditions for each one. They were able to adjust for almost everything.
They won the US competition and went on to Europe where they also won.
Honestly, at this point I know it’s late and I’d be happy with a rocket that flies up, doesn’t explode, and lands safely in 2 pieces
This is due in 10 days?
Give up this year, get head start on next year. You need to be testing at least a month ahead of time.
I’m a former UTA Aero Mavericks member; we did almost this exact project, and we used up several months building these things. Now, we were full time students that prioritized our grades, so I bet you could do it faster than that, but even today I would still want two months to do it at least (with few distracting obligations during those months), or perhaps 200 man-hours. I’m sure more experienced people could knock it out in under 50 man-hours (I never did certify), but still.
Edit: apparently contest rules will limit what we could do anyway.
Anyway, I think this allows me to talk about what we did / used on our project, since saying what we did and how well I thought it worked isn’t telling you what to do.
We used OpenRocket and our altimeters were generally Featherweight Ravens. We put our eggs in soda cans, filled the cans with expanding epoxy foam (in such a way the egg was held in the middle), then cut it back out and used the egg-shaped void, foam filled soda cans as our egg holder. I don’t think the soda cans were that great, but iirc they did work. The lander itself was a little thing that folded out like a flower when the hot wire (controlled by the altimeter) cut the line and let the spring open it; it was all on a parachute that I believe detached from the main lander at the same time the flower mechanism was cut loose (on the ground). We were DQ’d since the line failed to cut, and since the rules required us to land “upright”, and that was the un-tripped flower mechanism’s job, that was that.
We spent a few long nights experimenting with the hot wire mechanic, a good month deciding to use the flower design, maybe another month assembling (the “petals” were carbon sandwich, and the springs that opened them were not stiff enough and had to be upgraded to a set that was a bear to install), and we never test flew until about a day before the competition proper. I wasn’t involved with the rocket itself; I’d budget a month for that.
I will say that a different competition vehicle of ours had a little too much black powder eject a vehicle once and murder it, and each time we calibrated thereafter I always insisted on dialing the amount down as far as possible. The Raven maxed at 90gs, and that little “super” charge pegged it out (and unplugged the battery and unseated the electronics and jammed some gears).
Again, we probably weren’t very time efficient ourselves due to the whole college thing, and I think a dedicated team of 3-5 that had a decent idea of where to start could do all of this in 2 weeks to a month if they didn’t have those other obligations and they skipped all flight testing. But we were a team of ~15, building 3 different vehicles (2 of which had “landers”), had 6-8 months (starting August / beginning of fall semester), started with several very experienced members, and were very homework-burdened throughout. And we also ran out of time for flight tests; that always happened, and every time it did we always felt like that would have been the thing to make us way better.
There was one time we built a thing way before the deadline (2 months) and got to test fly; we came in 8th instead of 25th that year. There was one other time we built a rocket about a month ahead of time, and it rained or something every weekend between then and the competition, so we still didn’t get to test fly.
I really think focusing on leveling up your rocketry skill ASAP for next year is going to be the best you can do.
Thank you very much. I’ll be sure to implement your tips in the future, and start much earlier. Sadly, I’m sure you’re right we don’t have time for that this year. This whole competition was dumped on my lap just recently, is there any way I could build a rocket that at least flies in the time given? I have all the parts from an apogee tarc kit.
Is there anyone else on your team with model rocketry experience?
Making a safe flight and recovering the eggs unbroken is not difficult.
Nope on the others with experience, unfortunately. But I’d be happy with a safe flight and unbroken eggs
