Table saw sled cutting drawers assistance
Hi there,
Will someone be around to give me hand with cutting some drawer stock? I rough cut them with my circular saw/mitre saw, but need them to be square so the drawer doesn’t come out wonky.
I’m guessing the easiest way to do this would be on the sled, but open to suggestions.
Should be pretty quick, I have 7 total (QTY 3 15 in wide and QTY 4 14 in wide.)
I’m enrolled in the lathe class at 7, so if anyone is around before then (or after, I suppose) and can just lend a hand be much appreciated!
Thanks!
Chris
FWIW, be advised that the Saw Stop is down. You will have to use the Delta.
It’s just the rip fence on the Saw Stop that has an issue (new part is on the way!). Using with a sled for cross cuts should be OK, unless there is an additional issue with it I am not aware of.
You are correct, but last night Andrew @Azalaket said he didn’t want anyone using the SawStop until the fence is repaired. He was concerned that someone would try to kludge a solution for something that required the fence. And the Delta is working just fine.
Thanks for the replies… I just used my router at home to get it done.
