This is not specific to the woodshop area, but to all the areas in the space:
Being excellent means cleaning up after yourselves when you’re done with your project. It is not limited to just sweeping the floor.
If you mill lumber and create a lot of sawdust and shavings, cleaning up after yourselves also includes disposing of whatever amount you send to the dust collector, whether it went to the Festool collectors or the Felder, or into the trash cans.
I came early before the Safety and Orientation class Friday to find this…
Not only were the bins full, but because the Felder was off, the automatic blow-by system had a gap to blow enough sawdust to cover about a half inch onto the floor between the hopper and the Powermatic table saw. It also covered both table saws so much that I could not see the color of the saw table tops. I swept the sawdust out of the way to remove the hopper. Then I pulled from under the Felder to combine with what I had swept away. It was enough to fill again one of the bags from the hopper. Thanks to Peter @BirdMan we could carry three bags worth of sawdust and two trash cans to the dumpster before class started.
If you don’t know how to check the Felder and empty the hopper, please ask so you can help keep it in good condition for others to use the woodshop. It’s not hard, and it certainly relieves the next person from the frustration of having to empty it when they were expecting to come and do some work.
As you plan to mill a large amount of lumber, please include time to perform the after-work that is always necessary, and if you need to, recruit someone to help–it just makes it go much easier.
