Ah, found it. Here’s pictures of Godzilla tormenting the cats.
For scale, this is our 22lb cat…
He’s sunning on the window ledge, taunting
Slogging towards completion…
Actually quite a bit of work to get here. Stud lines were initially transcribed onto the tyvek before the last layer went up. Then they were extended down to the point they could be transcribed onto the cheater board. Each panel has to be cut by 1" lengthwise (why did I not use a 1x2 cheater board?), 16" centerlines drawn, then hole locations marked. Since this is the outer strata that adds some strength to the inner, I’m doing roughly double the fastener density to maximize strength.
In Theory™ my offsets are different so I shouldn’t hit any other fasteners. In reality, I didn’t hit any axially, but some poor planning resulted in hitting a few laterally. Oops. That’s what paintable caulking is for.
It’s not apparent. but the realities of squareness (or slight lack thereof) forced me to lay these out so that subsequent panels had to slide under the last installed panel. Took some gentle fine-tuning with a mallet but I managed to coax them into position; here’s hoping the other side does not suffer this problem.
@kyrithia - some bonus content for you:
Time for the usual progress report!
⅜" stock isn’t known for its rigidity, thus the panels are almost guaranteed to warp, thus two points of contact along the lower edge is the best one can hope for.
Adding to the conundrum, squareness in carpentry is an ideal, an image in one’s mind, a perfection to strive for that just doesn’t exist in the real world.
Upon snugging up the panel on the right to the one on the left, two problems manifested. First, contact with the cheater board on the left side was a distant rumor. Second, the panel wasn’t aligning with its neighbor. Much struggle ensued, but I thought I had it lined up, committed a few initial screws, made a too-cursory glance at the seam then happily drilled all the pilot holes. As I was working my way down that seam my error became apparent. [sigh]. Much re-rigging later I get a more satisfactory fit and re-drill pilot holes.
Went through almost an entire tube. Thankfully it’s cheap.
no reptilian help today?
No shoes shot, again?
Almost looks like a shed!
Lizards were laying low or something.
The end is truly in sight. One more weekend and the thing can be painted, minimally trimmed, and enclosed.
Vaguely contemplating a class at some point:
How not to Build a Shed in a Few Short Weekends for Less than $1000
Just think…by the time the paint is dried and you are done with the interior shelving / fixtures - the weather should be cool enough to start moving stowable items in without breaking a heavy sweat!
Load in comfort!
Took a comp day and it was like Amish Spring Break jokes.
Looking great.
I wish I progressed at all on mine- haha, procrastination strikes again.
The climate this time of year all but encourages procrastination.
Got the bulk surface painting done today and much of the trim (window, vertical) painted. Home Despot naturally doesn’t actually carry the door I wanted locally so looks like I get to shim in the next best thing - thankfully smaller and reasonably convenient dimensional reduction.
Took photos, but honestly it’s paint and looks a lot like Thursday’s photos. Look up “Silver Blue Sea” and “Gray Metal” Glidden paint if you want visuals.
So I do a lot of spreadsheets and CAD trying to calculate materials…
In this case, I determined I can do the ‘siding’ for the roof truss ends with eight 12’ 1x4’s. Fifteen 21¾" slats with 15° cuts offsetting steadily increasing amounts will do the trick.
Or I can buy one sheet of plywood probably at a lower cost and certainly less effort. Choices. So many choices.
90/90 rule is thoroughly in effect.
My caulking technique is kinda sh_t. Oh well. Some of that can be touched up later.
It is my sincere hope that I can get the “slat siding”, vertical trim, and door installed tomorrow.
What are you going to do once this is done?!!
My love of flavor crystals is not so great that I’ll ever realize that many coffee cans.
I actually really like the look of that. May have to copy it.
A guess would be to see if Nicole wants to build one in here backyard.(in keeping with being excellent to others)?
Erik’s Shed Service
Open June - October 11AM-6PM
Must provide lizards and water.
My rates and other demands will be profoundly unreasonable.
