Another day off, another progress report.
Yes, working outdoors in July is slightly daft, but in addition to working at a pastoral pace, I do stay hydrated. Roughly 3/4 of a gallon worth of fluids between those two and I drained the big one twice.
So today’s tasks…
- Finish the primary roof structure - only 4 more rafters to go. Not going to futz around with the remaining purlins today - that’s more fitting than I think I can stand
- Start deploying the sheathing that’s supposed to give the frame strength against parallelograming as @PearceDunlap would phrase it, however I believe the proper term is shear strength. First task is to prep the “trim” boards at the base of the platform whose real function is to give the sheathing (and later the siding proper) something to stand on during the treacherous “workholding” phase.
Measure, index, score. Done this numerous times on the project. That triangle and awl have been my most-used marking tools.
Also, FFS why is there metric on my ~20 year old measuring tape? Were 90s construction tools like 90s cars with a boggling mixture of SAE and metric?
Ah, the displeasures of painting. I think I managed to get as much as 90% of the primer onto the trim pieces.
This part really sucked and took an agonizingly long time. But at least all the rafters are in. Idea was to prime the parts of the roof that will be outright exposed or semi-exposed. I need to devise a filler piece for that outer rafter on the right…
From the other end. I’m really glad the framing is all but done.
Now that the gentle Texas sun has rendered the trim pieces dry, time to install them. Can never have too many clamps in woodworking nor carpentry.
I keep threatening to just build around clamps…
CAD dimensions said I’d need to trip about 5/8" off. I wished otherwise. However reality lined up with the CAD drawing…
Trimmed and secured.
The traditional milestone photo.
At the very least I hope to have the rectangular sections done tomorrow and hopefully the complex interfacing with the roofline. Maybe even the rest of the purlins.
