Faced with the prospect of actually getting started on this thing this weekend, simplification of the design has set in.
Found a true 36 x 80 door, which happens to have a skosh more clearance than necessary to get my widest piece of equipment in and out. Out with the 3-part door and out with the accessory access door. A ramp can still be arranged if I feel the need, but the chipper-shredder is not an every weekend tool, so perhaps it need not be integrated. Pre-fabbing the framing - the bulk in pairs of identical side-sections - should make for a brief assembly sequence.
I’m fretting the piers yet. I helped my father build an 8x16 shed ~25 years ago that used landscape timbers as piers with up to ~18" of clear under the back end; don’t recall the count - might have been a mere dozen on 4’ spacing. I dug those boreholes with a typical 6" posthole digger then we simply filled as if they were fenceposts. Dad loaded that shed up with some untold mass of his lumber stash and it looks to still be standing:
Sure, it could be any shed with the artifact-y mess thart is 3D satellite view at that level of granularity, but the 9/2014 street view reveals distinct features and design embellishments :
Given that I’m not going to load tons of lumber into it, perhaps I’m overthinking it - gravel at the bottom, flare the top ~6" if I’m feeling really paranoid and call it done?
