Hello,
I have a large steel workbench in great shape that would be a perfect donation for makerspace projects
Please post pictures. It might be useful in blacksmithing if it isn’t too big.
6ft by 2.5ft and 3.5ft tall roughly
Can easily handle heavy weight. Thick steel
I’d like the dimensions please. We need a table for our heat treatment kiln.
Dimensions above are as close as I can get without a tape measure on hand
I can bring it by now
That might be perfect. Any idea how much it weighs? Where are you located? How might we collect it?
Im like 15-25 mins away
Roughly 150lbs
We can bring it to you at Makerspace if you prefer
I’ll be there at 6:15PM or so tonight. In the blacksmithing shop. Just come around to the loading door around back furthest from the dumpster. Text me at two one four 773 six 889. Sound good?
It’s not wheeled by any chance?
Its not wheeled but the base can go on 4 wheel dollies easily
A couple of cheap HF 4 wheel dollies would easily make it very easy to move around
These are what I put on my heavy work table at home:
Welded the plates on with a few spot welds; the actual casters can be removed so they are out of the way once bench is in place and then put back on whenever it needs to be rolled around.
Dan, it’s likely you are familiar with these or even seen them in action.
