I’m trying to login to the laser cutter and it’s telling me that my username or password is invalid when I try to log in. However, I am able to login to this forum, and login to my account using the same information. Any ideas?
I figured it out.
Still having problems getting it to hold a new origin, and it wouldn’t take a second pass on the only cut that worked. It only worked once. Any help will be greatly appreciated.
Regarding the origin, in lightburn you have to set that you want the job to use the ‘user origin’ before you send the job to the laser. It’s set in a drop down menu near the send button (I believe the other options are ‘machine origin’ and ‘absolute position’). By default it will use absolute position which means the laser will ignore the origin you set and run the job wherever you placed it in lightburn. I think once you change it, it should stick for that particular computer.
