Since there was a programming error on the community kiln, is it possible the small kiln was also programmed wrong and is fine? is a test scheduled?
There was a loose/unconnected connector in the controller. We can run a quick test when there is a gap in the community kiln firings to confirm it is good to go.
Yes, opened it up with Chuck and he found a bad connection in the controller. Will confirm that it is good to go asap.
