The Sinterit Lisa is up for sale or trade to make room for new printers we can use in 3d fab. The printer will be sold as-is, no warranty of any kind, WYSIWYG. Any of these terms may change. bidding is now open and shall continue until 8:00 pm April 4th 2018 after which time i shall message the person to arrange payment and pick up.
If you would like to make an offer on the Sinterit Lisa you can send an email to [email protected] or send a private message via Talk.
you shall be given everything that was given to us when we received the printer. This item is worth $7,000 to $9,000 but i shall consider every bid. Serious bids only, aka no unicorns or special services remember this is for 3d fabs printers.
Dimensions 620 x 400 x 660 mm (24,4 x 15,8 x 26,0 in)
Weight 41,0 kg (90,4 lbs)
Power supply One phase, recommended AC outlet power 1,6 kW
Voltage 110/120 V or 220/230 V
Material Powder PA12 or Flexa Black
Max. build volume 150 x 200 x 150 mm (5,9 x 7,9 x 5,9 in)
Max size of high precision print PA12 – 90 x 110 x 130 mm (3,5 x 4,3 x 5,1 in)
Flexa Black – 110 x 130 x 150 mm (4,3 x 5,1 x 5,9 in)
XY accuracy from 0,05 mm (0,002 in)
Min. layer thickness 0,075 mm (0,003 in)
Min. wall thickness 0,4 mm (0,015 in)
Software Sinterit Studio 2016
Supported file types STL, OBJ, 3DS, FBX, DAE, 3MF
OS compatibility Microsoft Windows
USB stick YES
Wifi YES
LCD screen YES
Touchscreen “4
On-board camera YES
previous owner never used- said it was too complicated for him, we never used, too dangerous for our area.
