Are we allowed to cut copper-plated (single-sided) PCB with either of the lasers?
I’m actually trying to cut through, rather than etch assuming this is even possible.
Thoughts?
Thoughts?
I doubt you’d get far, but it’s fiberglass (epoxy) so you shouldn’t try.
The PCB router is tested but needs some minor finishing items and a HEPA vac to collect the nasty fiberglass dust as it’s hazardous to your lungs. Once the vac is purchased a pickup nozzle will need to be created and mounted to the spindle.
