Finished restoration and installation of a large (5.5” jaws) post vise I picked up in the Panhandle last fall.
The vise was muddy-muddy (apparently the dirt-floor shop had flooded and the vise was laying on the ground/in the mud).
Disassembly and a going over with a wire cup brush took care of most of the mud and surface rust. Fortunately the screw box is in good shape and the threads were in very good condition. The jaws open and close smoothly and align well.
The handle was bent (probably from using a cheater bar), but a little heat and I was able to straighten it. I actually did this at DMS last fall.
The bar spring which opens the jaws was missing, so I fabricated a new one. Similarly, the wedge which holds the vise on the clamp was missing (two large nails were in place as proxies). This was pretty easy to fabricate as well for a tight fit.
I’ve mounted it on the stand which previously held my smaller 4” post vise. Curiously, the larger vise is about 1” shorter, so I’ll need to shorten the mounting post or shim the bottom of the vise leg to adapt.
I applied a coating of blacksmith finish (a mixture of beeswax, boiled linseed oil, and turpentine ) to blacken and protect the metal.
