I needed a small piece of shim stock To get my part to run true . I vaguely remembered that the cellophane wrapper from a pack of cigarettes could be used . I wasn’t sure so I measured. It is .0007 in. . (yes I meant 7 ten thousands of an inch ).
A milky way candy wrapper is about .005 I think. .
So I will be saving time by using that to shim up one chuck jaw to make the 303 rod run true on my lathe. It had .002 in run out .
Another tip on a lathe .If you remove the stock and want to cut on it again .mark an arrow(on the stock pointing to the jaw it came from.)
Back when I was first exposed to machining, everything was measured in “thickness of a cigarette paper”, which was “one and half” (thousandths of an inch), if I recall correctly…
Thank you for sharing your hard-earned tidbits!
In the maker space the lathe usually has a big 3 jaw chuck. there it would be quicker to use shim stock than it would be to change the chuck . I would use a 4 jaw chuck at home if i had one. that worked. I might look at buying one but will need a back plate too.
