Do we have a shear that will handle 16ga mild steel? The cut length will be ~32". I don’t mind needing to break/deburr edges but I can’t have any significant deformation of the metal (it needs to sit flat on a solid surface without the edges curling up or down).
If not, does anyone have access to a waterjet (or whatever) that could cut this? At least one portion of this is going to be a donation to the laser committee (they just don’t know it yet)
If the normal shear is operating correctly, it will do 16ga mild. However since it’s a stomp shear it will need a little push.
The Dynatorch can also do sheet with the fine cut consumables. If done correctly with fine production settings, the heat should be even to prevent curling.
The stop shear might need a little TLC [it has been a long while since I tried to use it though] - and a lot of stomp. My vote is the Dynatorch [I also think you will have less distortion than using the shear].
I’ll check it out but I’m going to go to a small waterjet place near my house and see if they can be sweet-talked into doing it for a reasonable price. I just need a couple of rectangles and will provide DXFs.
That stomp shear won’t do 16 gauge it’s rated for it but it’s been abused. Use the Beverly shear in the metal shop or the plasma cutter. The shear in the machine shop would work but I think it’s only 24 inches long.
It’s probably been used enough that the blades should be reground. More important is checking the blade gap: Too wide and the metal folds, too tight and it pinches.
I’ve seen 16ga cut on this also, it does take some force
