Good afternoon, I am not able to sign in to use the SG1000 is there someone i have to sign up with first? I am a member and my credentials dont seem to work? please help
The big vinyl cutter is a Training Required machine. @cvrana or @CaryF300 can teach classes on that. Probably a few others as well.
@luxpartydiva, You have to take the Dye Sub 101 class to get access to the dye sub printer.
I’ve added a Dye Sub 101 class to the calendar for January 23rd. It should show up within 72 hours.
Isn’t the Titan vinyl cutter also Training Required? I do know that you’ve got to log in to access that.
Yes, the vinyl cutter is. I’m not entirely sure what the OP is trying to use. The SG1000 is the Dye Sub printer.
Aha. I didn’t know that. So that’s definitely not going to cut vinyl.
My fault. I assumed the SG1000 was a name for a vinyl cutter that I didn’t recognize as this was originally in a thread about vinyl cutters. Adjusted thread title.
