Seeking four heavy rubber feet for CA
Does anyone have four heavy duty rubber feet, or can you point me to a local source? I couldn’t find any in the big box hardware stores.
I need four feet that can be screwed to the (flat) underside of the matte cutter in CA, which is very heavy. It has bolt heads sticking out of the underside. Some people apparently drag it across the butcher block table in CA - making massive grooves in the table top.
Self-stick bumpers will not be sturdy enough to stay on.
Can the bolts come out? I have seen nylon table leg bolts/ leveling feet. Not sure if that might interfere or not.
I think I have some that I used for my largeinkle loom. They attach with a small screw.
Hockey pucks?
Literally.
I don’t think the bolts can come out, but they are not in the locations where the feet would go. The feet would need to provide about 1/4" of clearance (if memory serves me) so that the bolt heads don’t scrape on the table.
Machine Shop has four isolator pads rated 1200 pounds each, will that do?
That is certainly a high enough rating to do the job. How would they be mounted to the bottom of the matte cutter?
The gray cabinet behind Haas has a feet drawer with a few sets of feet in it.
I’m wanting to replace the rubber feet and bolts from the Titan cutter with some small casters… The feet as they are now, don’t really do anything for the cutter.
Wow Brandon, now those are FEET !!
@Adam_Oas, I crawled under the Titan and looked at the feet. Those would be perfect for the matte cutter. Could you please put those aside for the matte cutter? Thanks!
Machine shop has buckets of casters. Get with me and haul them away!
Yep. I’ve got a plan for one of the smaller sets of casters. Will get on it someday…
