I was cutting plywood using the sled and the blade dropped.
It doesn’t look like the mechanism engaged as the blade is not into the metal block. When I raise it, the blade stays in place but the blade guard moves. Any help will be appreciated.
Thank you
It goes up sometime but drops again
Let’s check the instant replay… @Team_Woodshop
I dropped it all the way down and raised it again. It seem to have fixed it .
I would suggest not using it until someone can take a look at it. “The blade dropped” should never happen and doesn’t tend to fix itself. If something is broken it is not safe to use. If it was something you did it is best to learn what it was so it doesnt happen again
