Ive ordered a 1/8 sieve that I should receive monday, Ill bring in.
Any quotes on this yet?
Forgive me for sounding picky, but that looks incredibly baby powder fine.
Like maybe it was recycled a few times? Thatās probably going to take
forever to strip anything.
My favorite thing about this thread so far is that dry air is āoptionalā
I have no idea what that media is, but āsoda blastingā, though not for āstrippingā, per se, uses regular old baking soda (just like in the Arm&Hammer box). Here is what it looks like new.
from here
Just saying that depending on what someone was needing, blasting media can come in lots of āgritsāā¦
Dry air is not optional; upgrading the current drying systems is (maybe) optional. There is already a trash accumulator on the line with a water drain on it at the point the hard line turns into a rubber hose (I checked last time this came up; itās there). There is also the system dryer at the compressor, so itās not like an effort is not being made. However, there is still speculation that trash/wetness is causing problems, so upgrading the point-of-use dryer might be a good idea.
Feel free to get a quote on a inline desiccant filter that could be used directly before the sand blaster.
I just put 4 50# bags of media next to the blaster (silica free). Go nuts.
Your face the first time I suggested installing a Passive Dryer. You wonāt like it 'cause itās not a quote.
Also, my sandblaster runs fine with the inline filter I already posted, but thatād just be a stop-gap for you guys.
Alternative buildsā¦Radiator
The price for the model he listed is shown as $6,250
April,
Forgive me for sounding picky, but that looks incredibly baby powder fine. Like maybe it was recycled a few times?
Hey, I SAID it was cursedā¦
Thatās probably going to take forever to strip anything.
What are trying to take off - chrome? Maybe I should have told you to use the coal slag after allā¦
Also, Danny just added 200 lbs so you should have a selection of abrasives.
Frank, I have no idea what the hell you are saying - the first time you put your face in the cabinet install a Passive Dryer? That doesnāt sound pleasant.
Huh? Is that some sort of British slang?
JAG āGoing Nuts Per Dannyās Directiveā MAN
Do you mean this link?
It is just a link to blasting tooling, and does not have specific piece of equipment in scopeā¦
Also, it appears youāre suggesting these solutions as being needed for the entire shop, not just for the sandblaster. I got no problem with that, if itās needed, and it may be, but I donāt think we should need any of these at the sandblaster. A simple inline water separator SHOULD be enough, although as noted, we already have a small one and if itās enough is some debateā¦
I thought you were already there, man. Already thereā¦
Is this still needed? If so, where should I leave it in the Metal Shop and can someone obtain Leeās permission for the donation?
Until we get something better, perhaps this might interest someone
Because Iāve never seen one, how do the pressure feeders work in terms of returning media for re-use? Is it a fill it up and use it til itās out and then stop to refill? or is there a valve of some sort to let it auto-fill when itās not under pressure? Maybe some other option?
sorry to bump an old post but its the same question as OP~ i have a specific application i would like to use SODA blasting and would like to check if it would be okay in this cabinet?
also i would like an official class on the new cab if anyone is going up there anytime this week or next maybe? i have done sandblasting before just want to make sure i use the DMS tools proper like.
First Iād advise checking on volume pressure requirement and nozzle oriface size to make sure itāll work.
Soda blasting is awesome. I remember a sales demo where the guy took a Sharpie, drew a line on a Coke aluminum can were the red anodize is then removed the Sharpie line and barely touched the red. It was impressive, but I recall we had a good size airline to it.
Good luck!
Where can one locally procure sand blasting media for removing paint from metal parts?
NW Home Depot near Josey and I35⦠no go.
Horror fraught or northern tools.
Danke 78901234567890
