Router working (degraded but functioning)
Since the Incra base is currently inoperable, the Porter Cable router has been installed using the handheld base attached to a temporary 1/2" plywood insert installed into the Incra table. It works reasonably well, but I would advise against the use of larger bits or try aggressive one-pass removal of large amounts of wood.
Additionally, the 1/4" collet has been moved out of the Porter Cable case and put into the drawer with the rest of the 1/4" router bits.
