Project Partners Rotary Tool Workshop: Contains Flexible Stylus, 72 Pc. Accessory Kit, and Tool-Hanging Stand
I have several of these, and will bring them to you at DMS. Please email me (through DMS site) your contact info, the quantity you want, and bring cash (I’m unemployed .)
New, factory-sealed Rotary Tool Workshop by ProjectPartners includes a variable-speed rotary tool, 36” flexible stylus, 22” telescoping tool stand, and a 72-piece accessory kit. This tool can be used for hobbies and crafts, woodworking, home repairs, refinishing, decorating, grinding, and polishing.
The 1/8-inch chuck capacity accepts all brands of attachments with 1/8-inch shank. Use the rotary tool with or without the detachable handle, or attach the 36” flexible stylus for greater control and precision. The 22” telescoping stand lets you hang the tool up to keep the table clear.
- Rotary Tool with Detachable Handle
- 36" Flexible Stylus for More Control and Better Precision
- 22” Telescoping Rotary Tool Hanging Stand sith Durable Plastic Base
- Accepts All Brands of Accessories with 1/8" inch Diameter Shank
- Variable Speed Control: 10.000-32000 RPM
- 120V, 60Hz, 1.0A Motor Enclosed in an ABS and TPR impact-resistant housing
- Limited One-Year Warranty
72 Piece Accessory Set Contents:
[floatl]* 2 Sanding Brands 1/4" x 1/2"[/floatl]
[floatl]* 2 Sanding Brands 1/2" x 1/2"[/floatl]
[floatl]* 4 Felt Wheels 1" x 1/4"[/floatl]
[floatl]* 6 Felt Wheels 1/2" x 3/8"[/floatl]
[floatl]* 1 Felt Wheel Point 3/8 x 3/4[/floatl]
[floatl]* 1 Sanding Drum 1/2" x 1/2"[/floatl]
[floatl]* 1 Sanding Drum 1/4" x 1/2"[/floatl]
[floatl]* 4 Diamond Cutting Bits[/floatl]
[floatl]* 1 HSS Cutter[/floatl]
[floatl]* 1 Aluminum Oxide Grinding Wheel 5/8" x #/8"[/floatl]
[floatl]* 1 Aluminum Oxide Parabolic Wheel 3/8" x 3/4"[/floatl]
[floatl]* 1 Silicon Carbide Grinding Wheel 25/32" x 5/32"[/floatl]
[floatl]* 1 Silicon Carbide Grinding Wheel 3/8" x 1/8"[/floatl]
[floatl]* 1 Stainless Brush Axial 5/8"[/floatl]
[floatl]* 1 Stainless Brush Radial 3/4"[/floatl]
[floatl]* 1 Polishing Compound[/floatl]
[floatl]* 37 cut-off Wheels Heavy Duty 15/16" x 1/64"[/floatl]
[floatl]* 2 Collets 1/8"[/floatl]
[floatl]* 1 Mandrel for Cut-off Wheel 1/16" Screw[/floatl]
[floatl]* 1 Mandrel for Felt Wheels[/floatl]
[floatl]* 1 Organizer Storage Case[/floatl]
[floatl]* 1 Chuck Wrench[/floatl]
[floatl]* 1 L-Pin[/floatl]
