Started assembling frame pieces, I initially cut the pieces the exact size and they wouldn’t fit into the jig, so I had to trim off 5-7 thousandths
I realized quickly that leaving the bearing in while fully welding was a bad idea, so I switched to using the top bearing only and removing it after tacking
I think the jig worked out perfectly, at least so far all the welded pieces look the same. Here are those pieces layed out on the next jig, they will be welded to some angle iron which will be the main backbone of the frame. Still have lots of crankshaft pieces to machine
