I am looking for advice or help (the hardware seems to be running i have gotten the xyz steppers to move.)
The two things I need help with.
- I need to do is create a set up for the Beaglebone Black C ramps hardware that does not use the onboard operating system graphic user interface.
- Second is to set remote user interfaces of QtQuickVcp.
I am using CRAMPS(https://reprap.org/wiki/CRAMPS) Board with Machinekit(http://www.machinekit.io/docs/getting-started/machinekit-images/).
I have done the tests with the screen and I have learned the latency of Graphics UI messes up the Scheduling of the real time system. Yet i can use remote user interfaces,which will put the hard work of the ui on the client side.
I am looking to use (vagrant and virtual box) as well as MachinekitClient.
Thank you for reading.
