Hello,
I was previously a member and had been certified in the woodshop. I believe it was around the end of 2016, beginning of 2017 that I stopped my membership. Back then we didn’t need to fob in to use the planer or jointer. I’m not sure how I can check if I currently have access to use them with my new fob. What steps can I take?
There is a small kiosk in the common room on the table near the lost and found shelves. run your fob over the reader and it will show what you have access to. You can print the list on the ticket printer.
If you’re at DMS, then there’s a RFID reader on the table in the Common Room, right next to Lost and Found. Scan your fob there, and it will list what things you’re certified in.
Thanks very much! I’ll check it next time I’m in.
Matthew, you will need to review the rules for the wood shop. A lot of changes since 2017…
is the online course an acceptable review?
https://learn.dallasmakerspace.org/course/view.php?id=11
