Resources for using the AT89C2051?
I have an embedded project that requires the use of this 8-bit MCU. As I have never used one before I’m not sure where to look for design software.
I have checked the Atmel site which recommends an assembly language compiler.
I’ve included a link to asm compiler below, but I would rather use C if possible
I found a gui for programming the chip with a schematic for building the programming hardware.
http://students.uta.edu/rx/rxr5243/projects/prog/2051prog.zip
I have access to a DataIO Unisite 40 that I could use instead of building a programmer.
I suppose what I’m really looking for is something that will work with the comforts that I have become accustomed to…like Atmel Studio but it looks like the device is not supported from what I can tell via www.atmel.com.
Worst case:
I write the program in asm and compile with command line tool. http://www.atmel.com/images/c51asm_win_1-2.zip and dust off the DataIO.
Please help me out if you can beat that setup with any solution used in the last 20yrs.
Cheers
-Brandon
@Brandon_Dunson I suspect you going to be stuck with the old technology approach. To the best of my knowledge, the 8051 series of micro-controllers are no longer recommended for new designs. And if that is the case development tools are not likely to be available of a modern design.
Of course, I could be wrong about the tools since I believe the 8051 is the single largest type of microcontroller still in use today…
This help? http://en.wikipedia.org/wiki/MCU_8051_IDE
If you can convince your employer to switch to something more modern, you’ll be in luck. I know that Keil has an 8051 compiler, but I have never used it and it is by no means free.
SDCC is a popular free, open-source C compiler for 8051s (and others).
If your project can stand 10x the cost for something more modern, check out LPC1114FN28, which is an ARM Cortex-M0 in a DIP package.
I suspect your requirement for an 8051 processor is based on legacy code which is “zero cost” to use, except that system designers frequently neglect adaptation and maintenance cost (programmer-months)
Kent,
That’s exactly what I was looking for. And thanks for not being a chip salesman, pushing me into another device without knowing anything about the project.
Cheers and thanks again.
-Brandon
Apologies. Not trying to sell you on another chip. Good luck with your project.
…especially in the military, the 8051 family is still going strong
Raisonance 8051 compiler appears to be free for hobbyist for up to 8K of ROM
http://www.raisonance.com/compare-8051-software.html
IAR offers a ‘kickstart’ version of their Embedded Workbench IDE/debugger/compiler that is fully functional (except for MISRA C support) and no run-time library source code. I’ve used their EW before for both MSP430 and some ARM stuff and it’s pretty good.
http://supp.iar.com/Download/SW/?item=EW8051-EVAL
In the past Keil also offered a code-limited version of their 8051 tool suite, but it’s not clear if that’s available any more.
http://www.keil.com/c51/
Wickenhäuser Elektrotechnik advertises up to 8K free. Tool date is 2005, though.
http://www.wickenhaeuser.de/
FWIW, Zach is an agreeable guy as long as you don’t talk about VHDL or Python in his presence. :laughing:
He’s definitely not a salesman, but if he was he’d sell you on Maxim products :smiley:
