I recently purchase a used Echo Power Pruner with known starting issues. Since I’ve had it, I’ve replaced and/or checked the following:
- Fuel filter
- Fuel tubes
- Air cleaner
- Carburetor & gasket
- Spark plug (confirmed spark)
- Spark arrestor
- Intake Manifold & gasket
I also am running new premix gas through it.
I can get it to start the first time, it will run only when given 50%+ throttle and dies before that. Once started, it doesn’t want to restart unless it’s set for a while or I’ve pulled the plug or carb.
Compression seems fine and there are significant differences with the plug in/out and the choke on/off.
Running out of things to replace and open to ideas…
