@Team_Woodshop The blade height adjuster has stopped working. I was lowering the blade and it was working but when I tried to raise the blade, it wouldn’t raise (adjustment wheel just spins). At this point, the adjustment wheel spins in either direction but the blade does not raise or lower. I taped a note to the table near the blade.
On the Powermatic table saw.
That happened awhile back it seemed the key stock had fallen out I got help from a machinist who made me another then I found the missing one on the ground nearby I would check there, I did leave the “spare” one on the wire rack next to the powermatic so maybe check there
Yea it’s the key. If the key is gone I’ve bought a bag of spares that’s in the maintenance box.
Someone really needs to clean the worm gear first. The key didn’t just fall out. The key missing is a symptom of the worm gear being full of compressed wood. The handle is binding and people just keep cranking on it.
Fixed. And some characters
Thank you!!
Thank you very much!
