[RESOLVED] Planer power - shouldn't be 45 amps
Page 10 of the operation manual says a 30Amp breaker is recommended. [EDIT: Correct info - 40A breaker is recommended].
This suggests to me that the manufacturer expects a lot less than 45 amps. Does this mean there’s something wrong with the planer if it’s generating surge current of over 45 amps?
Someone needs to confirm this. While I really hate to keep jerking around the engineer, we need to know this before we actually build …
@Mrksls2 - do you have any thoughts about it?
EDIT: Quote is from @Robert_Davidson - it’s not obvious that Talk carried that over correctly.
Keep in mind its probably inrush or Locked rotor amps. Typically 2.5-3 times the full load amps. Go with what the manufacturer says.
Have we ever replaced this breaker?
Also does anyone have any info on the panel or breakers we are using?
EDIT: Stan says it is on Main 4, breaker 32. I have replaced my photo.
Dunno if the breaker has ever been replaced. That might be worth a try …
But I think I need to back up. I think I gave some bad information.
Is the planer running on single phase 208V? Because if it is running on single phase, then the manufacturer recommends 40A breaker.
Can you get a look at the motor plate on the planer?
It should say
Um, no, I’m not at the space.
IIRC its 1ph
So the four on the bottom of page 23 all seem plausible, four being least likely. I believe it’s a 3ph I’ll be at space for a tour tomorrow and pop in to check
It is most certainly single phase. We used the jointer drop before the planer had a power drop.
The circuit drawings that Chuck Graf drew also suggest it’s running on a single phase 30A circuit.
In which case … manufacturer recommends 40A breaker and we have it on a 30A breaker.
:poop: That could explain a lot …
That & they suggest 230 instead of 208.
My bad I was thinking of the model number being 209hh and went stupid lol
Is 240v single phase the same as 230v single phase in the same way as 110v, 115v, 120v are the same?
At 208 volt you are going to see additional current so it would not be uncommon to bump up the current capacity of the breaker to handle the surge current.
Your absolutely right it’s the initial surge current I have graphs of the power consumption if you would ever like to see them but from what I am seeing the breaker as it is can not handle the surge current.
Are those breakers rated for a set number of trips? I’m sure that breaker has been tripped quite a few times, but I don’t know the expected behavior of repeatedly being tripped over time.
Panel 4 breaker 32.
Breakers tend get weaker as they trip more, In my experience anyway.
Likely I don’t know the details but that is common on most breakers.
At 208 volts that’s 44.23 amps which is pretty close to what Robert said is being observed. Sounds like a new and thicker line needs to be run that’s capable of 50 amps or more. Or wait until the move?
