Hello. The planer is not turning on. It may be the fob reader. The breakers seem all good.
Can you please help?
Thanks.
Alper
Thanks.
Alper
Is the fob reader showing a red light?
No. No light. No sound.
My fob worked fine with other machines.
The RFID box isn’t getting power. Flip the breaker to reset the power.
Also check that it’s plugged In, swap the jointer and planer plug if you can
If you can’t figure out what breaker just unplug, wait 30 seconds, and replug it.
Planer is back online
Thank you!!!
Please go to Burt @SWA’s post above, and check the box for Solution (you’re the only one who has that option since you’re the OP). That way the title will show a check mark and people will know that the planer is back on.
