[RESOLVED] Left printer clogged
Lefty is still having extrusion problems… even after the nozzle change. What it seems like is happening from the outside perspective is the extruder cannot grip the filament or the filament is being blocked or pinched prevent it from being extruded.
I had lefty strip the filament 3 times with two different filaments mid-print.
Just printed a whole set of parts and test grid on the whole bed. I re-taped the build plate, Lisa made sure the Z-height is correct. With the pure white filament it had no issues with stripping. The nozzle doesn’t seem to be clogged.
Javier, Jake (@jakew1ll), and Mitch (@themitch22)…
Thanks for reporting what seemed like an issue with the nozzle. It turns out that the Z height was way too low causing the filament to not extrude properly. Several items were printed successfully last night, so it should be all good now!
Thanks again!
:smile:
