Did anyone come across a black wallet/wristlet I may have left last night (1/25) ???
In addition to spreading the word here (good idea, I’ve had good luck in the past), be sure to check the Lost and Found shelves in the Common Room.
If there’s a delay in you getting to the space, perhaps someone could check the shelves for you. As far as CA room, might mention where in the room to check for you.
If you have a bin, might post that as an option for the object to returned. It can help in cases where maybe someone is concerned with anonymity. Also if someone checks for you and finds your wallet, they could put it in your bin for you (name/rough location in sea of bins is helpful).
I found it! But thanks so much for the advice! I appreciate it
