[RESOLVED] Far Righty Connection Error
When I was heading out, I paused the job mid-print and when trying to re-connect to the printer, the software wouldn’t connect and kept repeating “M105”. Not sure what that error was but it didn’t seem to resolve. Edit: A quick Google search later and it looks like M105 refers to getting the printer temperature from the printer. It did seem to be cooling down when I left but I guess the laptop might need a restart to get the connection going again.
-the purring dork
Hi Matt
When that happens, usually all you have to do is:
  1. Close the Pronterface application
  2. Press the red reset button on the printer
  3. Wait a few seconds, then open the app and “reconnect”
That usually resolves the issue. If that doesn’t work, then restart the laptop (and for good measure doesn’t hurt to press the red reset button on the printer while the laptop is restarting).
This type of minor issue is a perfect example of something that could be quickly answered and resolved via our unofficial Google Hangout (3D Fab “chat”).
I was at the 'Space after you left and Far Righty is connected just fine now.
Thanks!
:slight_smile:
The USB connector on the back sometimes get’s shoved against the wall disconnecting the printer, I think someone tried to fix that but it might have happened this time.
