I was having more issues with far righty warming the bed. Taking more than
30 minutes from ambient.
The temp sensor reports 107degrees, but the infrared temp gun showed
118degrees.
Jay Johnson
118degrees.
Jay Johnson
I tested the power supply for low voltage (that would cause long heat times) and it was at the correct setting.
When I timed it the bed came to full temp in ~8 minutes with the hood open.
If you see a problem like this next time let me know asap without changing pronterface so I can get as much info as possible from it. It printed successfully and was printing when I left.
@JayJohnson600 - Jay, thanks for reporting the issue.
@PearceDunlap - Pearce, thanks for looking into this and providing an update.
