For some reason my dongle has stopped working for wood shop tools. I have checked my active directory and I am listed for wood shop basics. It used to work fine. Any ideas?
What tool(s) are you having trouble with?
Some of the RFID readers can be slow to read/sensitive to where on the panel they read.
If it is all of them you might check in the common room to see if anyone can help. Tagging @patrickpleez1 - Are you at the space?
David - PM your email and I can check tomorrow morning if it is not fixed tonight.
Thanks!
I’ve resolved this.
Thanks
Freddy
Thanks Freddy!
Out of curiosity, what was the solution? AD credentials out of whack, a hardware issue, or something else?
For whatever reason the sync between the interlocks in the woodshop and active directory had not occured. I populated tne appropriate field on the interlocks and off to the races.
Thank you very much!!
