Background: I need to pour some clear resin inside a small metal pot. I will place baked polymer clay inside the resin. The inside of the pot will be painted white (probably enamel). The resin, when hardened, is supposed to look like a pot of pasta cooking.
Question: Is there some type of resin that won’t interact with the paint, or some type of paint that won’t interact with the resin? It just has to last long enough to harden without getting completely milky - a little bit is OK, because pasta water looks a little milky as the starch releases.
I can’t powder coat or enamel the pot because I used solder that is too low temp for those applications. And I also have the outside painted.
