Refractmeter results for Colchester lathe
Just FYI - we dug out the refractometer and tested the lathe coolant and the pre-mix bucket.
the current lathe coolant is at roughly 5% oil to water. the pre-mix bucket came in at only 6% so someone might
consider mixing up a more potent batch next time.
Bob K and I discussed making a universal batch at 8% which can also be used on the HAAS but in the end, the HAAS has such a large water tank (50 gals) that any premix would just get diluted to an unusable level. We’ll continue to do that seperately. there is about 1-1/2 gallons of concentrate in the teachers cabinet for mixing.
cheers!
That’s my fault. I had to eyeball the premix bucket when I added water to it. I’ll draw gallon calibration marks on it next time I fill it if someone hasn’t beat me to it.
You did fine. 5% is the very lower limit, 10% is the high.
Propose buying eight of these 2 gallon jugs.
no worries. were not scientific about the mix.
