I have a Wyze thermostat that is apparently sensitive to over voltage It was working for a while, then it started popping the fuse on the AC controller. After some back and forth with Wyze, they say it’s because my transformer is outputting around 28vac, and the thermostat can’t tolerate much more or less than 24vac. Don’t know why it worked for a while before this issue unless my AC voltage in my house fluctuated a little (wouldn’t be surprised).
Here’s my thermostat controller, a White Rodgers Intell-Ingnition. Any way to reduce the AC voltage without swapping the transformer?
