OK. Precise is relative. I have a metal part which is manufactured at a precision metal shop. What I need to do is apply a protective film down on the inside of the part, making holes for the studs which are located at various locations.
What I’ve done so far is cut a template on the laser cutter and then cut and drill the material based on the template. This actually work OK for the first 6, but I noticed a pretty serious problem with the process.
There is some scaling / error introduced somewhere because the actual part cut by the thunder is not exactly correct. The original part drawing is in ACAD (dwg). I convert this to DXF using a discontinued Autodesk program called Autosketch. Then I import the DXF into Adobe Illustrator and save it as a .ai. Lastly, I import it into RDWorks and cut with the laser. This results in a very slight error which accumulates from the center of the part as X and Y increases. My part is roughly 48" x 20". The accumulated error is aprox .125" in the X direction and .050" in the Y direction at each end. The center of the part seems to be perfect.
Currently, I can verify that my tools seem to verify that the conversion from DWG to DXF doesn’t seem to introduce any error. I’ll have to get back to DMS and check further down the chain.
Anyhow, I am very interested in other options. The direction of cutting a template (maybe CNC?) and then creating a plywood fixture with right angle alignment corners seems to be a good one!
