A few pics of the current project - not necessarily in order:
For those not familiar with rear wheel drive these photos will give you and idea of what lurks behind the wheel and tire on the typical pickup truck (also covers those rare rear wheel drive American cars still on the road)…
Brake rotor / disc above
Brake rotor removed - axle pulled part way out - This shows a set of small brake shoes that are used for the parking brake.
Cover removed from the differential - the axles are retained by thick ‘U’ shaped c-clips.
Non shiny area is caused by bearing failure - should be smooth and shiny. This means the axle must be replaced.
New axle next to old axle. (new axle came in today- correct axle I should say). Photo also shows “aftermarket” differential cover that has a screw in magnetic dipstick which also acts a fill port. This cover doubles the capacity of gear oil needed, also has a large magnetic drain plug and tapped/plugged ports for accessory indicators.
New bearing and seal installed.
Will clean up the oil residue before inserting the axle.
