I’ve got some questions about the pink foam used in the drawers where we put all the MultiCam bits, collets, wrenches, so on.
What kind of foam is it? I don’t remember it being specifically mentioned in the Advanced class.
Would it be useful as custom padding for shipping? Or is it too soft, brittle, etc.?
Where can I get some? I checked toolfoam.com but it didn’t show the pink stuff.
@fedakkee @rablack97 @cghaly @eric24 @Kentamanos Your input would be appreciated!
Ok, I’ll include @Tapper then too. Tapper, your thoughts on this foam?
I haven’t seen it, but “pink foam” sounds suspiciously like builder’s foam. Is it sorta hard?
It is styrofoam sheathing from Home Depot. Lowe’s has blue if is more appealingly to your color pallet.
Hope that helps.
Chris
What Chris said. Its pretty resistant to falling apart, and cuts very well on the CNC router.
Thanks, Chris & Tapper! I might ask you more questions offline later. I’m trying to add padding to checked baggage I’m taking on a flight and am hoping this will be better than copious bubble wrap or crinkled paper.
Any chance this foam would work with the hand-held router as well? The base of this item is not flush in the corners and would be difficult to model on the computer.
It’s called ghosting, and depending on the type of foam yes it can be done with a hand router. My one warning is to go slow because as the tool heats up it can melt to the bit and cake on making a poor cutting head. Not so common when using a Cnc, speaking from experience; it happens when doing it by hand.
Owens Corning pink foam (brand name Foamular) like Dow Chemicals’ blue foam ( brand name Styrofoam), are both extruded polystyrene, aka XPS.
It is approved for, and cuts well on the lasers (with a careful eye and high speeds recommended).
Strength ranges from 15 to 60PSI compressive strength:
Foamular Type:
X, 15 psi minimum comp. strength, 1.30 lb/cu. ft.
IV, 25 psi minimum comp strength, 1.55 lb/cu. ft.
VI, 40 psi minimum comp. strength, 1.80 lb/cu. ft.
VII, 60 psi minimum comp. strength, 2.20 lb/cu. ft.
V, 100 psi compressive strength, 3.00 lb/cu. ft.
Both brands usually have a thin plastic film on either side which makes it stiffer and a bit more impact resistant. It can be peeled offf with minimal damage to the printing on the sides.
@heyheymama … how would you feel about me finding a place to add this info to the laser tips on the wiki?
