If I wanted to smoothly knock off the edge on a piece of brass round stock, is there such a bit for a sherline or taig micro lathe?
The bits I seem to come across over & over again make facing, cutoff, or plunge cuts, but I can’t find anything that’d mill in a clean consistent rounded edge of any dimension.
When I think round-over it’s always been for a router in woodworking in the past. So perhaps I’m just not using the right name for the bit you’d put into a lathe tool-post.
To be clear - I don’t want a flat beveled edge - I’d like a slight clean consistent round over.
