Went looking thru my notes and found this:
http://spaennare.se/pwmdig.html#chap62
He uses CD4k series parts. A simple 4 bit version can be built using 74xx85 4 bit comparator and 1/2 of 74xx393 4bit bin cntr. Ckt has some short comings. Can wire to achieve 0% OR 100% - probably there’s a way to get both. Will never do an exact 50%. You’re cntng 0-15 so there’s never an exact center point.
Built ckt using 8 bit cntrs and comparators. Cntrs were limited to 0-59 cnts (6 bits). 6 bits determined the pwm and also decoded to 2x 7 seg rg led splys. Got really messy fast. Ckt build (minus decoder) mostly worked - watching the pwm on scope had occasional glitch. Idea was to implement in VHDL and pgm fpga. Purely a design what if exercise.
Moving on - wrote (ugly!) pgm on arduino uno. Much easier and works. Clock digits index an array which has pwm values. Drives 2x 7 seg rgb dsply. Interesting to watch dsply go from one color to the next in 60 steps.~QED.
