You know, it doesn’t actually do too bad with Blender. It doesn’t import under the .3ds format but under the…COLLACA(?) format it imports as a solid object and you can divvy it up from there. Scale is off so that’s a bit of an issue but you just need to know a single one of the true measurements to find the ratio you need to scale it down at.
What is that going on between the Common Room and the Purple Classroom?
each room looks like its modeled individually. looks like its just moved off a bit as a unit
You are right. It looks like the Common Room was slid out by several feet.
Good eye Bill. It is off when lining up with the Purple Classroom. I’ll fix it when I’m up there and can see what’s going on with it all
Classes are on the calendar for learning Blender and how to make virtual representations of objects and spaces. If you know absolutely nothing about Blender, it will take you these two classes to make scenes like those pictured above. Intro to Blender takes place on the 9th and 16th at 8pm and Designing a Virtual Space takes place on the 10th and 17th at 8pm. Hope to see ya there!
