This is a bit of a one month progress report.
The FLEX file system (File Management System or FMS) is feature complete except for the portions dealing with the creation, reading and writing of random access files. FLEX stores data on disk as a linked list of sectors. Reading or writing an arbitrary location in a file is not a simple arithmetic calculation; a naive implementation would have to read every sector of the file to follow the list until the needed sector is found. To solve this problem, creating a random file adds two special sectors which contain the addresses of the sectors in the file as they are allocated. Reading a byte from random location in a file requires first reading this sector map then the sector.
The FLEX user interface is feature complete except for enhanced error reporting and background printing. When a random file named ERRORS.SYS is present, its contents is used to present a meaningful error message instead of an error code number. This capability is dependent upon FMS random access file support. Background printing is an option which requires a source of periodic interrupts. I have not investigated this feature very much yet; there are hooks for it in various parts of the system.
The third leg of the FLEX system triad is the Utility Command Set, a collection of small programs on disk which provide a large majority of the user commands. The following commands have been implemented:
ASN
BUILD
CAT
DATE
DELETE
JUMP
LINK
LIST
RENAME
TTYSET
VERIFY
VERSION
leaving these yet to be implemented:
APPEND
COPY
EXEC
I
NEWDISK
O
P
PRINT
QCHECK
SAVE
XOUT
The bootstrap loaders work so the operating system can be loaded from a disk image.
The system total so far is about 9K bytes of machine code. That is an average of around 300 bytes per day. It may not seem like much, but remember that it is all written in assembly language.
The current memory map is:
$0000…$00FF - Zero page, locations at $12 and above are free for application programs to use
$0100…$017F - FLEX line buffer
$0180…$01FF - Stack
$0200…$033F - FLEX entry points, variables and printer driver
$0340…$047F - System File Control Block
$0480…$0AFF - FLEX Utility Command Space
$0B00…MEMEND - User memory
Somewhere above that is about 6K of FLEX itself.
Unlike the 680x versions, the UCS area has been intentionally placed adjacent to free RAM so that a program needing maximum memory can easily use both.
The User’s Guide is almost ready to publish; this is slightly modified from an original FLEX manual. The Programming Guide is about halfway done; it is a heavily modified version of an existing FLEX manual.
Finally, some preliminary work has been done on an editor and an assembler. The assembler subproject is actually comprised of four smaller projects:
enhance the existing 6800 assembler to add features such as conditional assembly directives
convert the 6800 assembler into a 6502 cross assembler running on the 6800
convert the 6800 assembler into a 6800 cross assembler running on the 6502
combine the three into a 6502 native assembler
