Priorities won't print in order?
Hello,
I’m using the Big Thunder and set my red and black as priorities 1 and 2, but no matter what I set them to they always print incorrectly. Has anyone had this problem? What could be going wrong?
Thanks!
Mew
It’s possible that it doesn’t recognize your red as red and it might be treating them both as black … in which case it would just assign whatever order it wants. Tell RD Works to not do black and see if it actually processes the “red”.
BTW, if you used Illustrator and your file color style was anything other than RGB, it won’t recognize your colors the way you think it should. If it doesn’t recognize a color, it just treats it as if it were black.
We solved this.
Solution was to go into
Handle » Cut Optimize
Then check the order of layer and inside to outside boxes
