Today, after Hot Process training and then MIG welding, Randy was nice enough to assist me in learning the controls for the large oven in the Metal Shop. While we were able to get the oven on and working, the control panel for setting time and temperature was a bit confusing. Are there any materials available that would explain how to set the digital controls? I’ve looked in the Wiki for anything and haven’t found anything. Any guidance on setting time and temp would be appreciated.
It’s just a standard PID controller. The manual here helps: 1/16 DIN PID Temperature Controller (For SSR) [SYL-2352] - $40.89 : Auber Instruments, Inc., Temperature control solutions for home and industry
But all you should have to do unless you’re changing the temperature is press and hold the second from the right button to place it in RUN when you start, and press and hold the far right button to put it in STOP when done.
Gracias!
20 characters
Thanks for link to the controller manual
