If purchased, we should consider getting the surface plate calibrated, putting a better cover on it (or better, not allowing people to set things on the cover), pick up a fresh tenths indicator and a good indicator stand (not the magnetic base type). That’s a good start to the measuring equipment we need to use a surface grinder.
If budget allows, consider a grinding vice as well. Grinding parallel surfaces will get boring quickly.
